Mileage till Empty Replaced by Speedlimit
Okay, so I'm not sure if this is a feature or a bug.
In the top line of the in dash data screen I have mileage till empty selected. At one point, I enabled the speed limit to be shown, which takes over the top line. I've since disabled that feature, but it still shows up. My milage till empty comes on when I start the car and from what I can tell randomly appears otherwise.
I'm a doing something wrong? How do I get it to display only the mileage till empty?
Mine seemed to do did the same thing - somehow reenabled itself!
It's easy enough to shut off again if you can find that feature buried in a multifunction gauge submenu. I decided to just leave it on since DTE is displayed by default on the trip info page also.
Could it be that when you changed it you forgot to save the changes to the key you are using? If you don't, then the next time you lock/unlock the car it will revert to the last saved mode.
Agree with what Nicoli said. I've got my car set to show the speed limit, and it shows the mileage to empty only when there is no speed limit information for the car to show.
