Engine drone sound
Ok, so I figured it out. Haven't really been able to drive the car in the last few weeks, but yesterday I put on my winter wheels/ and tires and decided to poke around a bit on the rear of the car. Got my head under there and low and behold the clamp connecting connecting the side muffler to the center muffler was missing both bolts! Nothing can really fall off the car, but on a high speed turn the pipes can slip apart. I am guessing when the dealer preformed the recall replacing the side mufflers, they never put the bolts back in this clamp! I could fix it myself, but I'll let the dealer sort it out.
I'm so glad I found this thread, because this is exactly what happened to my C2S Cab last weekend. To make matters worse, this drone sound occurred first after I got my car back from a good friend of mine who took it to Napa with his wife. I didn't dare to ask him what the heck did you do to the car, it sounds different than before!?
Now knowing that I am not the only one hallucinating I'll take the car to the dealership to have it checked out.
Old thread. New issue. 2020 GTS with exhaust drone in normal mode at about 80 mph on the highway. Anybody notice this?
You may literally be on your own here, with the only 2020 GTS. The stock exhaust is quiet in normal mode though, maybe vacuum line disconnected from flaps.
On my bone stock 991.2 T, there's definitely a loud and vaguely irritating drone between 3-4K RPM with PSE on; when lifting off or coasting. I can deal with it normally (character, right) but seems to switch on and off "digitally" right at a certain RPM threshold, which is the irritating part, making it sound very artificial. It goes from no drone to DROOOONE and then back again with a feather on the throttle. I would expect the noise/drone to increase in a relatively linear way, but it is literally like flipping a switch. Now I just drive with PSE off or just make sure I am continuously running at higher RPM ....
