Although I enjoyed washing my cabriolet on a weekly basis by myself, there are times when I needed her to be clean in a hurry to head out.
Is it safe to use a touch less car wash from time to time? I am more concerned about the fabric convertible top getting ruined by the soap they use at the car wash. Or am I a little paranoid?
Drive it dirty, until you can properly wash it. In addition to JamesKen's notes, I'd add, concern about the wheels and low profile tires in their track system.
A friend of mine owns a carwash and told me the obvious: you need one of two things to get the dirt off a car, friction or solvents. Touchless car wash has to use much harsher detergents to make up for the lack of friction.
I agree with LexVan...drive it dirty if you have to.
I've used them on my Bentley GTCs & my R8 Spyder and never had a problem. I, too enjoy washing my cars and using de-ionized rinse water, blower to dry, etc., but an occasional touchless car wash is no big deal, IMO.
At least the touchless car washes in my area have no wheel nor track. I just drive in, put car to park and the robot arm goes around the vehicle spraying water and soap. Then I drive through 3 big air blowers at the exit. Looks inoffensive. I guess I'd stay away as much as I can.
I used them a couple of times while traveling out-of-town. On my previous cab, I did have a mishap, where the water pressure slightly changed the drivers side window seal. The window leaked from then on, with any rain or when washed(by hand). Had seal replaced under warranty, which resolved it.
Noooooo! How could you even think of using any car wash. I agree, drive it dirty. Just remember it got pretty dirty in that cargo ship and it's clean now
One other point, all car wash places recycle their water. Most thru just a sand filter, so the PH of the water goes out of sight. Removes the wax along with a little dirt.
The touchless wash near me is the same system. However, last time I used it (on my 996 TT Cab) too much water got into the engine area and it took a while to dry out and run properly. Don't use it anymore but have found a hand car wash not too far away (no tracks and everything by hand) so tend to use that now.
I'd vote for driving it dirty. The touchless car washes use a more vigorous chemical agent in the cleaner since there is no physical agitation to remove dirt. That'll strip wax, and who knows what it will do to your cab top.
Could you just use a spray quick detailer and microfiber towels for touch-up cleanings to remove dust in between washes? That's what I do and my car is clean every day.
Repeated exposure to soaps on our cabriolet tops is murder on them. Mine might see soap once every two years, and that's only to prep it to receive the Ragg Topp Protectant.
If my car was on fire, I just might consider running it through a car wash.
