PSE question
I just had PSE installed on my base Carrera at my local dealer ... it sounds great, of course.
However, I noticed this morning that it only works in Sport or Sport Plus mode regardless of the switch position. In other words, if you are not in Sport or Sport Plus, you can press the button all you want and the light will go on or off but no burbles and crackles for you.
Is that how it is from the factory?
I am in Sport mode 90 percent of the time anyway, but if my wife is in the car I leave it in regular so the downshifts are not so ... well, sporty. Less violent. LOL
But I still want to hear that PSE.
Not the case in my car, I have PSE from factory, and if I press the button I have the lovely PSE sound without Sport or Sport Plus mode.
Now if PSE is off and I press Sport or Sport Plus, than PSE is automatically selected, and you can deselect it if you want.
Basically I can run PSE without Sport and can run SPORT and Sport Plus without PSE if I so desire.
The Coasting fundtion is the one that bugs me because it only works if you do not suppress the start and stop function.
Go back to your dealer and test drive a car with PSE from factory! Maybe he forgot to code something in your car, or maybe something changed, mine is a MY2012 C2S.
I can hear the PSE if I push the button even if I am not in sport or sport plus but the difference is not very big and at first I was disappointed. Now push sport plus and the pops and gurgles at down shifts and the roar above 5,000 rpm is pretty impressive.
Just tried it on my S today, turned on PSE w sport chrono OFF and you can hear the exhaust note change. Then turn on sport chrono w pse and i could swear its a bit more throaty. Or is that the sound imposer? Either way its a bit more exhaust tone w sport and PSE ON.
Anyone had this installed or had considered this X-Pipe on their base Carrera (no PSE)?
https://www.fabspeed.com/carrera_991_16.html
Drive through a Parking garage or Tunnel open your windows and test it. In my car there is no difference between PSE on with or without sport/sport plus on.
Again, as I turn PSE on, no matter which mode I am in, the sound just changes and I have all the pops and gurgles, and it is loud. Louder would be obnoxious.
Drive through a Parking garage or Tunnel open your windows and test it. In my car there is no difference between PSE on with or without sport/sport plus on. Again, as I turn PSE on, no matter which mode I am in, the sound just changes and I have all the pops and gurgles, and it is loud. Louder would be obnoxious.
Sent from my iPhone using Rennlist
