Sound system -> No Sound!
Strange phenomenon happened to me this morning as I fired up the car to go to work. I first could hear my parking sensors beeping as I was backing out of my garage. Then as I drove off, I realized I had no music from the radio. The PCM display screen looks normal and responded to my touch as it should, but just no sound at all. I cranked up the volume, nothing. Press the mute/unmute button, nothing. Shut off PCM and turn back on, nothing. Parked car, turned off ignition and turn back on right the way, still no sound... So I thought to myself, ok I'll bring the car to the dealership after work. As I got in the car after work, everything worked as usual... any thought?
Same thing happened to me, pulled into the house music on then pull out an hour later... No sound.
Checked Fuses and connections nothing blown or loose.
Fired up the next day everything was normal, weird.
This just happened to mine this morning. Hoping it will be fine this afternoon when I leave work. I did restart the car at a traffic light this morning, but still no go. Tried switching from FM to BT Audio and got nothing either. Phone still worked through the speakers though.
