2,000 mile / break-in service?
First service is just an oil change at 10.000Km
Rainier
2000 miles is probably a good time to stop by your dealer and have the service team look over the car...check tire wear, fluid levels, answer any questions, etc.
My service team discourages premature oil change as wasteful and unnecessary. They said it might be considered if one plans on parking the car for the winter, but really only if it makes you feel better.
Here in the U.S., first scheduled oil change is 10,000 miles.
There's a way to access any info notices on the mini display - perhaps try that to see if there is a service notice there.
I had the service light come on and the dealer says this is a known fault but no permanent fix yet. They just reset something an it went away and has not come back (reset about 4 weeks ago). They did the PDK software upgrade at the same time and what a difference to snappiness of shifts in Sport +
The intermittent service warning started coming on after 1k miles and again after 2k miles. The dealer reset the warning on both occations and I was told that it is a SW issue and that there is no fix yet. Expect it to be fixed in a future SW update. There is of course no reason to do service after 1k and 2k miles.
I had the oil changed at 2K. Also, did an oil sample for spectral analysis. But at 5K what a difference in the 3.4L's operation. Much quieter at idle and super silky smooth power band. We did only long trips for the first 5K, also (all since June 17th). This what the factory recommends, and it obviously makes a huge difference.
