R compound tires for 991S
Can anyone recommend a 20" R compound track tire for the 991S?
Limited so far with Pirelli Corsa being the only choice on Tire Rack.
I was hoping they'd release the Dunlop Sport Maxx Race in the 991S sizes, since it will be on the GT3. Damon, any idea if 305's will fit on the rear of the 991S? (Non-4 S)
Damon, what is the outlook for the availability of Michelins PSS in the appropriate size for the 991 4S?
245/35 Diameter Variance: 0%
295/30 Diameter Variance: 0.81%
305/30 Diameter Variance: 1.69%
As long as under 3% all should be Savy
Zook, this is good info on the Trofeo's. I need to replace the stock tires, and was going to go with the Michelin PSS but there is currently an availability problem. The 305/30 Trofeo's fit fine on the stock 991S 20" wheel? Just double checking that no spacer's, rolling, etc. is required.
Also, do you have any sense of the sticky vs longevity as compared to the Corsa, stock or the MPSS?
I would love it if I could use 305/30 instead of the 295/30, as that opens a couple options up. I'd love to hear definitively from someone that this works on the S, as John's asking. Also, I've heard that Trofeo's only last a couple track days, which would make me pretty hesitant to buy them, especially since they're probably more expensive than the Corsas.
Former Vendor
Former Vendor
Porsche has about the highest bar out there, and they simply will not N rate a tire until it gives them exactly what they want.
Not much of an answer I know, but it's the best one I have. Honest.
305's are supplied on the rear for the 991S 2 when you order the Sport Techno wheel option. These wheels are 1/2" wider front and rear than the other 20" supplied for the 991S 2.
That would lead most of us to believe that the 305 might not fit well on the 20x11 wheels.
