need advice on left-side bottom exterior scratch
scratched, dented and purged to the inside slightly (as you can see from the attached picture).
Porsche centre mechanic tells me I must replace the entire rear-left steel plate body to fix the problem (vs I would have thought just simple small arial dent issue).
what should I do? any good advice kindly?
I think that bottom piece is plastic and has to be replaced. You have some damage on the body too that looks like a minor fix, but will be pricey since you may need to paint. You might as well fix the wheel rash too
That is minor but will be pricey to fix. Where I come from that damage is more than a 'scratch'.
Laszlo_Laz (04-19-2022)
As others have noted, the surface damage to the wheel may not be entirely cosmetic, so it has to be checked for true and roundness. A good wheel shop can mask and repair that lip and have it 99% match to the front wheel. If you go with insurance, just have the wheel replaced with a new factory part. Whatever else happens, have a dealer tech inspect all suspension parts and chassis pick-up points at that corner of the car, then redo the alignment to at least measure it. It quite likely has no damage, but if you're unlucky, the curb could have contacted the wheel carrier. Anything with any "witness" marks should be replaced.
Give or take the wheel refinish, maybe a pinch in the tire sidewall, alignment, labor, paint, metal work, fabricator labor, at least in California, it's $2000-$3000 before the dust settles. I'm sure you could find a "quickie" shop to do it with a wire brush, bondo and "decent" paint, repair the wheel with the tire on, you could be back to daily driver "good" for $500-$1000 and who knows, a curb could jump out of nowhere and it all happens again tomorrow.
that pic shoulod be sent to porsche ... thats why 911 porsche should always be a manual Gear .. damn PDK
thats 2 crimes in 1 action ... damging a porsche and stealing it ????
