PDK in Sport Auto mode
Yes but further up someone mentioned Porsche's had been doing this for years I think.
I sure was impressed with the 991S with PDK doing this. On the Autobahn at about 125mph someone cut me off not realizing the left lane was stopped a very short distance ahead. I used brakes only to avoid hitting him and the "blip" happened from 6th down to 2nd in a very few seconds. All on its own.
Im sorry, but when you say blip are you talking about a quick depression of the gas pedal quickly followed by letting it off?
Maybe im not getting this, but if that is what is being discussed what does this do as opposed to just aggressively punching the gas which in any mode drops the gears? Sorry if im missing something obvious, had a travel day from hell and been sitting in business reviews all day.
My contribution to the OP is that for my fun runs around the forest roads im really enjoying sports plus in manual.
cheers
cheers
cheers
cheers
cheers
cheers
Downshifts by blipping the throttle are a characteristic of ZF transmissions for some years now. I don't know how long. Their 8 speed automatics (the best slush box auto IMO) also do this unless for some reason the car manufacturer has changed the logic, which happens quite often.
ok I'm feeling very dim
if you are driving a PDK in gear then a blip of the throttle will
result in acceleration. however brief the blip. if I want to change hear without accelerating I just use a paddle. I'm not trying to be petulant, what am I missing here?
cheers
cheers
Trust me. It won't accelerate. Just a fast snap of the pedal.
This isn't a throttle movement so much as it is a tap with your toe. Obviously, some physical movement of the pedal takes place or the position sensor wouldn't detect your action, but it is too shallow and too brief to cause an engine speed increase.
Honestly, I have no idea when it would be used since we have the levers on the wheel to command a downshift. The mechanic told me more as a curiosity than anything.
Gary
I tried it coasting on relatively flat road a few times and could not get a downshift while coasting (e.g., the freeway off-ramp), so it's not configured too well IMO and I'm sticking with manual shift until my 991 arrives.
Jwgilmore (12-02-2019)
