Dimensions of center console cubbyhole
Will a 991 owner without the smokers package in the 991 be kind enough to post the measurements of the little square cubbyhole in the console? LxW and the height (depth) in the back and front ,as I realize it tapers off in depth.
Since I had missed a PM from mtbscott and was suprememly unhelpful, I will try to get some karma back here.
Now, the edges and corners are rolled, so these are my best efforts:
Width front 2 10/16
Width back 2 6/16
Length 2 5/16
Depth front 1 14/16
Depth back 1 4/16
Also, the front and sides taper a bit as they go deeper, and the back side tapers by quite a bit.
Width front 2 10/16
Width back 2 6/16
Length 2 5/16
Depth front 1 14/16
Depth back 1 4/16
Width front 2 10/16
Width back 2 6/16
Length 2 5/16
Depth front 1 14/16
Depth back 1 4/16
Width front 2 10/16
Width back 2 6/16
Length 2 5/16
Depth front 1 14/16
Depth back 1 4/16
Yes, front of car.
(To be truly accurate, one could probably also use the dimensions of the rubber bottom insert, which would give the leaning in/tapering of the sides. But I didn't have anything to pry it out with.)
