Help! .. PDCC in Carrera 4s
Old Oct 20, 2012 | 06:25 PM
saint.666's Avatar
saint.666
Exclamation Help! .. PDCC in Carrera 4s
Hi..
I have a few days left to lock my order for Carrera 4S .. but this issue of PDCC is bugging the hell out of me .. i read nearly every post on this topic and opinions are divided so the only valid conclusion i can draw that it ultimately a personal choice .. and that's fair enough
However i feel the issue of PDCC has not been covered with regards to 4-wheel drive and therefore request your guidance..
for my prospective im considering PDCC because:
1) This will be my 1st Porsche ... thus im not going to be missing that Porsche/911 feel that every 1 is talking about
2) Im not major track person ..so lap-times is not concern.. however i do go for a drive on some twisty roads every weekend
3) We have the worst roads ever ever ever .. its criminally bad !.. and from what i read it seems PDCC provides a more comfortable and forgiving ride .. especially that ill be including SPASM in my order..
However the following concerns me:
A) its well known that 4-wheel drive cars tend to under-steer a bit.. so will the PDCC improves or worsen the under-steer?
B) This seems to be complex system and thus there could be maintenance issues down the line
I know that 4s has not yet been driven and thus its more difficult to provide a constructive opinion .. Nonetheless id really appreciate some feedback in view of the above factors
Old Oct 20, 2012 | 06:31 PM
dochusar's Avatar
dochusar
Difficult to answer your question as the 991 4 and 991 4S are available to test drive. I drove the 991 S with and without PDCC without spasm as my roads are notoriously bad after each winter. I decided not to opt for PDCC, and went with the regular PASM. I used my money on a glass sunroof and the sports design package. I would recommend that you drive the 991 S with and without PDCC to see if it is worth it for you.
Old Oct 20, 2012 | 06:43 PM
saint.666's Avatar
saint.666
The dealers over here are completely sold out !! .. all the cars on delivery are sold too ...
Old Oct 20, 2012 | 06:52 PM
Dag Johnsen's Avatar
Dag Johnsen
If trackdriving is not important, ordinary PASM.
PDCC would add comfort and I think no problem.
Dag
Old Oct 20, 2012 | 08:16 PM
iambon's Avatar
iambon
I m amazed how good is PDCC , actually I feel like there is no body roll at all and I can attack corners with confident.
There is other cars drive and turn like 911 with PDCC.
Old Oct 21, 2012 | 06:14 AM
Dag Johnsen
Hi..
If the roads are so bad you DONT want SPASM. Normal PASM are WAY more comfortable.
PDCC or not, as long as you dont trackdrive the car, it will be fine with it.
Old Oct 21, 2012 | 07:27 AM
chuckbdc's Avatar
chuckbdc
SPASM lowers and stiffens the ride with shorter stiffer shocks and roll bars.
PDCC has nothing to do with comfort. It neither stiffens or softens the ride- it keeps the car from leaning in hard cornering (barely perceptible in low speed cornering) by dynamically adjusting roll rate.
Old Oct 21, 2012 | 08:52 AM
aljaberh's Avatar
aljaberh
I think the normal PASM will be a better choice for our roads (am from Qatar) i was really confused whether or not to go for the SPASM & PDCC but found it more convenient to stick with the standard PASM and spend the money on other options
Old Oct 21, 2012 | 09:37 AM
CDinSing's Avatar
CDinSing
Agree it does not play in suspension softness. With SPASM and PDCC you get a stiffer roll bar but by having the end links soft it is like having a disconnected/soft roll bar when you are cruising or driving straight and one wheel hits a pot hole! Bam! But only one side of the car reacts, little to no force transferred across the car as would be normal with a hard bar. That is comfort, confidence and safety especially on rough roads in normal driving.
I would agree with regular PASM it is not needed. The suspension and bar are soft enough for comfort.
Old Oct 21, 2012 | 09:57 AM
o2bcdn's Avatar
o2bcdn
I have a 991S with regular PASM and PDCC. I can't say enough good things about this combo. The ride is excellent on crapy Illinois highways and very well controlled on the track (I do 4-6 track days per year). Compared to me 997.2 C2S, the overall ride comfort is dramatically improved - the ride more supple over bumps, potholes, railway tracks etc and the interior is noticeably quieter. During a 991S test drive, it drove over a railway crossing near my house. In my 997.2 I always braced a little for the crossing, it would rock the whole car and I could feel it through the steering and the seat. The first time I went over that railway crossing in the 991S I said "wow, that was amaingly smooth" to the salesman. It really impressed me.
The PDCC option does not directly improve comfort, but it does indirectly. If Porsche wanted to achieve the same no body role, flat cornering qualities without PDCC, they would have to use extremely stiff sway bars - those very stiff sway bars would reduce comfort and suppleness of the ride. So, PDCC does not directly make the car more comfortable, but it does make the car more comfortable for the relative amount of cornering stiffness available.
I am very happy with PDCC and would not consider buying a Porsche without it, except perhaps a Cayenne diesel, in which case cornering prowess would not be the reason for buying a vehicle like that.
My 2 cents. Good luck!
Old Oct 21, 2012 | 01:58 PM
ADias's Avatar
ADias
The problem with PDCC is that in a low sports car it masks the 'seat of the pants' feel - if you understand what that means and are tuned with the car.
It's excellent on a Cayenne though.
Old Oct 21, 2012 | 02:25 PM
SiNi's Avatar
SiNi
PDCC plus regular PASM potentially gives you best of both worlds - the lack of body roll without having to have harsh suspension on the bumps! My understanding is that the PDCC system on the 991 is a new design and cannot necessarily be compared to PDCC on other P cars. Also the whole "feel thing" on track is surely a case of learning how the car behaves with PDCC by lots of practice especially if you are a novice with regard to driving a high performance car on a circuit.
Old Oct 21, 2012 | 03:19 PM
saint.666's Avatar
saint.666
Thank you all for your feedback ..
With regards to SPASM .. my decision to go with it is aesthetic .. lowered suspension with those wider arches and 305 back tyres..perfect !
i know its gonna create an issue with roads here .... but all i wanted to know if PDCC will give some advantage on the terrible roads here
my other issue is under-steer .. The guys at Motor Trend say that the PDCC creates under-steer ...
http://www.youtube.com/watch?feature...&v=Upd03eZjzIo
That test was made with C2S (2-wheel drive) .. so i guess it could be worst in the C4S (4-wheel drive)..
your opinions on the under-steer will be appreciated
Old Oct 21, 2012 | 03:47 PM
Betternotbigger's Avatar
Betternotbigger
Not on mine it doesn't. Contrary to expectations I can always feel what levels of grip are on offer.
Old Oct 21, 2012 | 03:49 PM
ADias's Avatar
ADias
You need to drive it harder.
