Electronic Oil Measurement..
All, I've noticed that I can check the oil level while driving. This is contrary to the OM that states you must shut off the engine, wait at least one minute before measuring. Are in "in transit" measurements accurate?
On a side note, I went and tried the Sport Plus mode today on a particularly long and smooth freeway on-ramp with no other cars around...that thing hauls **** and the PDK shifts were simply vicious
On a side note, I went and tried the Sport Plus mode today on a particularly long and smooth freeway on-ramp with no other cars around...that thing hauls **** and the PDK shifts were simply vicious![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
My guess is it's a glitch. On my 996 you get a message if the car is moving, not level, or not up to temp.
It's probably not a big deal unless you aren't getting accurate readings when measuring using the proper procedure.
I think I'd want to be sure since the electronics are the only way to measure the oil.
Noticed this as well while driving through Europe. My Touareg requires a two min interval after shutdown before oil level check will work. OTOH, my 650 gives the level check while driving after the engine is warm. Interesting.
Spyder
Spyder
