991 sales beginning in early 2011?
Old 02-21-2010, 01:29 PM
  #46
At Law
At Law's Avatar
Originally Posted by geof
Better start saving for that Ferrari...
That is hilarious. Well done.
There had better be a place in the cab to put my spitter and
enough room in the bed to haul around my Karaoke equipment
and rodeo saddles. Dale Earnhardt Sr is alive afterall....
Old 09-10-2010, 12:29 PM
  #47
stevepow
stevepow's Avatar
Das Camino - looks great!
Old 09-10-2010, 01:35 PM
  #48
996FourEss
996FourEss's Avatar
The four inch wheelbase has been widely confirmed. I also understood that the increase was being combined with reduced overhangs, so overall length of the car was unchanged. Car stays as a rear-engine design of course, not sure how you keep the trade-mark glass house design with a mid-engine flip (which is, frankly, what the Cayman / Bosxter already is, namely, a 911 design with a flipped engine / transmission).
Old 09-10-2010, 03:25 PM
  #49
tincanman99
tincanman99's Avatar
Does this mean that 997 values will plummet when this comes out?
Old 09-10-2010, 03:30 PM
  #50
Edgy01
Poseur
Edgy01's Avatar
If the front end looks like a 996 -- NO!
There will be some gradual drop in the 997 prices simply because it's not the king of the hill at the moment, but time will only tell whether the 997 is a lasting model of the 911 series, or just another in the lineup.
For example, the 993 appears to fair far better than the 996 although the 996 is a newer and better built car. It's more emotions that drive that.
If years from now it is decided that the 997 is just a pretty car and that the 4 inch stretch on the 991 changed the '911' significantly, then the 997 will be favored with a higher residual value.
Old 09-10-2010, 03:44 PM
  #51
zanwar
zanwar's Avatar
They've been lengthening the wheelbase one way or another since 1969. It always improves the handling of the car. This time won't be any different.
Old 09-10-2010, 03:48 PM
  #52
Nugget
Nugget's Avatar
Heresy. I don't think a longer wheelbase improves handling at all. I love that the 997 has the same wheelbase as an MX5 (although I could do without the three foot front overhang). Frankly, if the wheelbase gets too much longer then the cars will stop being "911s" in my mind. Minimally they'll lose an important aspect of why these cars are so great.
I think they just do it to accommodate the increasing size of drivers over the past decades. Longer wheelbase is for cabin room, not for handling.
Old 09-10-2010, 04:15 PM
  #53
chopperzz
chopperzz's Avatar
Originally Posted by FlatSix911
Nugget, you have my vote for the Best Post of the Year ! ...
I second that vote!
Old 09-10-2010, 04:40 PM
  #54
zanwar
zanwar's Avatar
When they push the wheels out toward the corners of the car it changes the high speed handing. It makes the car more stable, faster to return to neutral. The car will be easier to anticipate and you'll be able to lap a track faster. For me, this would be an improvement. If you like to throw the car around at slower speeds and you enjoy the oversteer, I imagine you wouldn't like the change.
They stretched the wheelbase back in 1969, and it had made the car easier to drive. The 912 was also reported as handling better than the 911 because it had a lighter engine. Each time they reduce the effect of the rear weight bias it makes the car easier to drive and quicker at the track. They've managed to do this consistently over nearly 50 years without ruining the positive aspects of the car. This time shouldn't be any different.
Old 09-10-2010, 06:49 PM
  #55
Nugget
Nugget's Avatar
"More stable" and "better handling" are not the same thing at all. In fact, I think they're sort of antithetical attributes.
Old 09-10-2010, 06:54 PM
  #56
cbzzoom
Registered User
cbzzoom's Avatar
When your starting point is the ludicrously unstable old 911, then yes "more stable" is the same as "better handling".
(obviously if you're starting from something too stable then the opposite might be true)
If you want something that's super nimble at low speeds, the 996/997/991 platform is not the car, regardless of wheelbase.
Old 09-10-2010, 07:54 PM
  #57
zanwar
zanwar's Avatar
Because there's so much mass behind the rear wheels of a 911, it's harder to make the car rotate, and harder to stop it from rotating once the motion has begun. If they move the engine forward or the wheels outward, they'll reduce the tendency of the engine mass to keep the car rotating. You'll have less potential for oversteer when throwing the car into a fast corner, and you'll be able to reverse the direction of your turn quicker. That's my understanding of increased stability.
Old 09-10-2010, 08:08 PM
  #58
Nugget
Nugget's Avatar
I guess we'll just have to agree to disagree. I think that a short wheelbase is fundamental to the 911's appeal and design. A longer wheelbase is undesirable to me given its impact on handling. I don't think it's the right direction for Porsche to take the platform.
Old 09-10-2010, 09:43 PM
  #59
StanThePorscheFan
StanThePorscheFan's Avatar
Porsche engeneers are reading this and scratching their heads: "Aah, so that what we've been doing wrong all this time! Sheesh."
Old 09-10-2010, 10:31 PM
  #60
Nugget
Nugget's Avatar
No, but I guarantee they're working hard to keep the wheelbase short while balancing against other demands for the platform. A longer wheelbase in the 911 isn't a design goal for Porsche, it's an uncomfortable but perhaps necessary compromise in the face of competing requirements. Porsche knows that a longer wheelbase detracts from the handling characteristics that the 911 is famous for.
Quick Reply: 991 sales beginning in early 2011?
