PADM sensor install
Old Mar 27, 2026 | 10:50 PM
dimeadip's Avatar
dimeadip
Default PADM sensor install
Anyone ever install a new PADM sensor without removing the mount from the car?
Old Mar 28, 2026 | 02:56 PM
keyontheleft's Avatar
keyontheleft
Someone on a youtube video did and by the looks of it, it seems quite doable.
Old Mar 28, 2026 | 06:18 PM
Joec500's Avatar
Joec500
Also removing the entire mount is super easy. If you have rhino ramps and a jack will take a first timer 2 hours or so.
Old Mar 30, 2026 | 11:32 AM
FLN2LO's Avatar
FLN2LO
Cruisin'
I did the sensor replacement with the mount still on the car. All I did to prevent the ferrofluid from leaking was taking the pinky finger of a latex glove (ripped off) and stuff it with a little paper towel. As soon as the old sensor is removed i just jammed it in the hole - a very small amount did leak but it was negligible.
Old Mar 30, 2026 | 11:33 AM
FLN2LO's Avatar
FLN2LO
Cruisin'
Use a small Dremel grinder wheel to grind off the little metal connections...
Old Mar 30, 2026 | 01:23 PM
Nashvegas's Avatar
Nashvegas
Curious if there’s a particular video avail online that’s best to use in thinking about this repair. ?? I’ve seen a few, not great.
Old Mar 30, 2026 | 02:46 PM
Joec500's Avatar
Joec500
The pelican parts one is pretty straightforward and clean:
