991.2 water pump failure rates
Old Dec 28, 2025 | 11:19 PM
DHL's Avatar
DHL
Originally Posted by HenryLee
Will dealers preemptively replace water pumps or must it fail to replace?
Depends on what you mean by preemptive. I believe there must be some sign of failure. In the case of my 2019 GTS, I found significant unexplained loss of coolant (level was down over a liter). The dealer then found evidence of dried coolant residue in some vac lines connected to the water pump. But there was no massive loss of coolant leaving puddles on the ground as happened with my 2017 C2S. A good reason to check your coolant level frequently (more than the oil). Don't wait for the car to tell you your coolant level is low. Mine was down over a liter and no warning on the MFD.
Old Dec 28, 2025 | 11:48 PM
asellus's Avatar
asellus
No, it is not a recall, it's an extended warranty.
Old Dec 29, 2025 | 02:55 AM
Sleevie's Avatar
Sleevie
Porsche GB advised the "The TI is followed when the symptoms are presented"
TI is the Technical Information Bulletin 1950 relating to replacement of the pump and valve block. There is no extended warranty for these components in GB. Mine was replaced under warranty because I bought the car as a Porsche Approved Used Vehicle with a 2 year warranty. The fault didn't show on the PPI, the 111 point inspection or test drives during the 4 months the car was at the dealership. On the day I bought the car I got the engine over temperature warning 100 miles from the dealership, about half way home, a few minutes after stopping for fuel. After the car had cooled down, the fault cleared and I completed my journey. The OPC collected the car, loaned me a GTS and did the repair under warranty. Interestingly they asked me for a copy of TI 1950 and said the fault was exactly as described.
A few months later, at a race meeting, I spoke to a few technicians from the OPC (they were part of a Boxster Cup team). They asked me how my car was performing. I told them about the pump issue and they said they'd done a few of those repairs.
Old Dec 29, 2025 | 06:14 PM
DHL's Avatar
DHL
Don't rely on the dealer to check coolant levels. Mine didn't even though they claim they checked all the things normal for a CPO. I guess coolant level is not one of them.
Old Dec 30, 2025 | 04:41 AM
Sleevie's Avatar
Sleevie
Agree, I checked the coolant level after the pump replacement. It was on minimum and I saw the odd dried drip of coolant on the pipework at the rear of the car. I contacted the dealership, showed them photos and said I might have a leak.
They said the level change was likely to be entrapped air in the system that had worked it's way out causing the level to fall. The dried drips were not unusual after working on the pump. Also advised checking the level when coolant was warm. I checked but it was still on minimum so bought a litre of coolant and added 500mls and the indicator moved midway. Its still on minimum when cold but I don't stress about checking it frequently now. It's been 8 months since I did a top up, mostly summer driving.
Old Dec 30, 2025 | 09:53 PM
DHL's Avatar
DHL
After the dealer did my water pump replacement on the GTS when I got home the level was at minimum so I added 50/50 (not pure water) to max the level. Then drove some aggresive acceleration runs, high G backroads for about 50 mi. Then let the car cool to stone cold overnight and checked again. Had to top up two or three times this way until the level stabized and stopped dropping. There are a lot of dead zones in the 991.2 coolant system and they are not all filled with that vac fill system.
I would not check coolant levels warm. Due to the large amount of coolant in the 911, the levels measured at that overflow tank will vary way too much. Plus if the coolant is too warm you risk overflow out the fill port and really messing up your level readings (not to mention scalding dangers).
Old Dec 30, 2025 | 11:04 PM
McKlyde's Avatar
McKlyde
Originally Posted by MingusDew
It’s a water pump, some people really be acting it’s a big deal, like it requires an engine out or something. In the grand scheme of engine “problems” it’s a fairly mild one with easy enough access for replacement. Not to mention, Porsche gives it a 10 year warranty on the factory part. If it happens it happens and you deal with it, if not, just drive the car. Either way, it’s a great car.
germany and water pumps! Iconic duo.
Old Dec 31, 2025 | 04:30 AM
DHL's Avatar
DHL
Funny BMW does not have issues with water pumps and they're German.
Old Dec 31, 2025 | 02:43 PM
spdracerut's Avatar
spdracerut
The BMW 335 from around the 2008 era were notorious for water pump failures. Really, water pump replacement became a normal service replacement every 40k miles as preventative maintenance, no joke. The initial warranty was for 50k miles and they often failed at 60k. Now that is some German engineering.... Later, there was a class action lawsuit.
I've never had a water pump issue on my Nissan, Honda, Lexus, or Mazda. Mileage between 90k-160k.
Old Dec 31, 2025 | 07:20 PM
Levy's Avatar
Levy
If you do some digging....you'll find every Mfg you list had issues with something at some point in time. some were pretty major....Honda/Acura trannies and Toyota/Lexus engine sludge...and MANY more. I sound like a broken record here but ALL mfg's screw up (some more then others). Perfection is not an realistic option when you have thousands of people (including outside venders/suppliers) developing a new vehicle over several years. someone/somewhere is gonna drop the ball. It's not like we're talking Lucus electronics in older British cars here (nearly undiagnosable and unfixable)....causing a lifetime of grief =)
Had a .1 c2s with minimal problems. Still expect the same from my .2 c2s (pump already replaced at 4k miles). This water pump "issue" was not a huge deal for me but did appreciate knowing and understanding it before buying. Porsche stepped up and took it on the chin with the 10 year coverage (unlike many Mfg's who wait until the lawyers tell them settle/fess up). Do see how some might feel differently. Imperfect world=imperfect cars....no way around that
Old Jan 1, 2026 | 11:00 PM
jt3sd's Avatar
jt3sd
Default So far..
My 2018 911T has the OG water pump @ 38K Miles, so far so good.
Maybe I should have it replaced at its 2026 annual service where Im already having the drive belt replaced, thoughts?
Old Jan 2, 2026 | 08:50 AM
Erwin964c2's Avatar
Erwin964c2
Just replace it for the latest version ( i believe v5). They are not so expensive and its a simple job to do and you will drive without the fear off breakdown. Also consider the expansion tank replacement . They wil will crack eventually.
Old Jan 2, 2026 | 12:46 PM
GoaterAz's Avatar
GoaterAz
Your water pump is covered by a Porsche Warranty through 2028; I wouldn't pay out of pocket to replace a perfectly functioning part.
Old Jan 2, 2026 | 02:53 PM
NA2's Avatar
NA2
i'll take a faulty water pump over VANOS failure, rod bearings, or a cracked subframe.
Old Apr 25, 2026 | 08:10 PM
abiazis's Avatar
abiazis
Not all 991 models.......
File Type: pdf
