PCM Carplay integration issues
After that, it would connect via USB consistently.
How do you, "went into the Mr12Volt Bluetooth menu and cleared out the phones"? In the system settings for Mr12V on the PCM? And how do you do that if you can't get Mr12V to launch on the PCM?
Bluetooth is one of the options on the main Mr12Volt screen - before CarPlay launches:
If you can't see past the first couple of icons, try turning the select (right) **** on the PCM and it will scroll to the other icons. On that screen there is an option to clear out the devices currently paired with Mr12volt. I can't find a sample of that screen, but if necessary I can go take one in the car. If you get connected to CarPlay and can't see this screen, press the Home icon in CarPlay and you should get back to this screen. Worst case, leave your phone inside and away from the car, and when you get to the PCM you should see this screen. You may have to switch the source to TV if it isn't already selected.
Once you get this cleared out, you should be able to have your phone in the car, and it should NOT connect to CarPlay until you plug it into the USB port.
I can get to the Mr12Volt > BT screen. I deleted my iPhone that was listed there. How about the “auto connect” box? On our Off? Since it is on the BT screen, I would expect it to be off, thus directing it to the cable. Right?
On the iPhone, on BT, forget Mr12Volt? Then, on the Mr12V screen select CarPlay?
I had it working earlier today. While having CarPlay running, I turned off BT and WIFI on the phone and it was connected/running. So cable works. But tonight I couldn’t get it to connect. Can you describe your car and phone set up and the procedure when you get in the car?
1. BT is off on the iPhone (earlier, on the BT list of devices, for Mr12Volt, I "forgot this device.") After connected by cable, I hope to be able to turn on BT.
2. iPhone is connected by USB
3. Start the car and get to Mr12Volt screen with icons.
4. On the PCM screen: Mr12Volt screen > Settings icon (all the way to the right) > General: "Auto start phone link app" checked "yes"
5. On the PCM screen: Mr12Volt screen > Bluetooth icon: "Auto Connect" box is "no" or empty
6. On the PCM screen: Mr12Volt screen > Bluetooth icon: I deleted my iPhone as a device on the right side of the screen
What a pain. I eagerly await a software update. By the way, I have the 2024 dated firmware for Mr12V and iOS 26.1 on the iPhone 17
Yes, Mr12Volt has released recent MCU software updates for its P2000 series, but there’s no confirmed fix yet specifically for iPhone 17 connectivity issues. Apple is also aware of broader iPhone 17 Wi-Fi and CarPlay bugs that may be contributing to the problem.
Here’s what’s currently known:
🔧 Mr12Volt P2000 Series Updates
- Latest MCU updates were posted on August 4, 2025, covering various vehicle systems including Audi MMI, BMW CCC/CIC/NBT, and Jaguar XF/XKR.
- These updates require a MicroSD card (≤16GB, FAT32) and involve manual installation via the P2000 unit.
- While these updates improve compatibility and performance, no specific mention is made of iPhone 17 or iOS 26 fixes.
📱 iPhone 17 Connectivity Issues
- Users are reporting Wi-Fi drops, Bluetooth instability, and CarPlay glitches—especially when unlocking the phone or accessing the lock screen.
- These issues affect CarPlay performance, including lag and audio skips, which may impact Mr12Volt devices relying on wireless connections.
- Apple has acknowledged the problem and is likely working on a fix, but no targeted iOS update has been released yet to resolve it.
✅ What You Can Do
- Check Mr12Volt’s update page for your specific car model and MCU version to ensure you’re running the latest firmware.
- Update your iPhone 17 to the latest iOS version available, as Apple may roll out incremental fixes.
- If problems persist, consider using a wired CarPlay connection (if supported) or reverting to an earlier iOS version if possible.
- Bluetooth is ENABLED on the phone, but there is nothing related to Mr12Volt or CarPlay
- iPhone is connected via USB
- When I start the car, and plug in my phone, I get the Mr12Volt screen, then the large icons, then a spinning connecting to CarPlay (with the white rectangle in the header), bluetooth icon is greyed out
- On Settings/General I also have the "Auto Start Phone link app". not sure what this does
- On Bluetooth screen, Auto Connect is checked, and Auto Answer is not.
- On Bluetooth screen, there are NO devices listed.
- Bluetooth is enabled, but there is nothing related to Mr12Volt or CarPlay
- Wifi is enabled (shouldn't matter)
- Settings/General/CarPlay I have CarPlay Vehicle listed - I can't remember where this came from, but you can click on this and "forget this car" to remove any extra cars from the list. Make sure there is no left over Mr12Volt cars listed.
I would try checking the Auto Connect box on the Mr12Volt General screen, and try again.
If you are still not having success, what do you see in Mr12Volt if your phone is NOT plugged in, and you do NOT click on any of the large icons? It should sit on the black main screen showing the icons . If you get the spinning "connecting to CarPlay", then it's still trying something wirelessly.
Assuming you just see the black icons, then you should be able to plug in your phone and wait. In a few seconds, the white rectangle should show up on the Mr12Volt header, and then the spinning "Connecting to CarPlay", and in a few seconds it should display. Occasionally, I have had to "wake up my iPhone and then it will connect.
Let us know how that goes...
The turn off menu sounds interesting - alot of people complain about the CarPlay/bluetooth connectivity after the car is turned off. Is there an option to have the PCM power down when the car is turned off?
I think I would prefer the PCM to power off when the car is turned off, rather than have to remember to lock the car in the garage every time.
I have selected “USB Only” in the system and BT settings with the cable connected, yet it still tries to connect wirelessly. How can that be?
11/11/25. On the iPhone with USB attached, Bluetooth is on. Turn on ignition. Mr12Volt tries to connect wirelessly, I think. Let it show in the BT device list but quickly “forget this device.”
On PCM > Mr12V > Bluetooth: CarPlay window upper bar shows the small phone icon as active and BT is grayed out. Auto Connect is turned off. There is no indication of the Bluetooth or the phone.
In Settings > General: car setting auto start phone link app is checked yes
In Settings > System is > Factory Mode> Phone Link Setting : shows USB and Wireless.
It is working!
Haven’t tried it yet but this fix just came out.
Our website is now LIVE! please visit us at https://ACSByRoman.com/Mr12Volt
Hard drive cloning and PCM BOOT LOOP repair
FREE INSTALL KIT AND CAR CHARGER WHILE SUPPLIES LAST!
On site install is available in the Philadelphia PA area as is Global shipping!
CLICK HERE JOIN OUR FACEBOOK GROUP
Torque.Acs@gmail.com - (267) 317-8229
