No Start
Old Jul 8, 2025 | 09:37 PM
zaskar15's Avatar
zaskar15
Default No Start
I occasionally have a no start issue, where when I turn the key it does not turn over. I get a message telling me to depress the brake pedal. But when I depress the pedal if feels stiffer than normal and still will not start. But after a few minutes, it eventually starts and the breake pedal softens. I tried stomping on the brake but still wont start. Any ideas, could it be the interlock? I had changed the battery last year and is on a tender when not is use so fairly sure not the battery.
Old Jul 9, 2025 | 08:22 AM
CSK 911 C4S's Avatar
CSK 911 C4S
Could be a number of things. One of the simplest is the $60 brake switch down by the brake pedal.
Make sure it's still attached and inline with what ever makes contact with it.
Old Jul 9, 2025 | 12:46 PM
Coppi52's Avatar
Coppi52
Weird, I had this same scenario yesterday with a 2025 Cayman Style Package loaner vehicle with 2000 miles.
Was parked in my garage for two days - set in park with e-brake on. When I went to start it, the brake pedal was super stiff / heavy and it wouldn't immediately turn over. Put the key back into upright position, waited a few seconds, then tried again. Started up but sounded a tad different than I remember.
Oh well, seemed fine after that and returned it to the dealer...
Old Jul 9, 2025 | 09:09 PM
DHL's Avatar
DHL
The brake pedal being stiffer is normal if the car has been idle for a while (the power brake boost system bleeding down). Sounds like that switch is bad or out of calibration and it needs a bit more pedal travel to engage.
