Away for the winter
Old Nov 20, 2024 | 10:55 AM
asellus's Avatar
asellus
Originally Posted by TD_05
How does a cover cause swirls?
It's pressing dust and dirt into the paint as you put it on or remove it, as well as any sort of jostling while it's on the car, such as from people/cars going by or air movement from fans, wind, etc.. This scratches the paint. Do it often enough and your paint reflection looks like a million spiderwebs in direct light.
Old Nov 20, 2024 | 11:13 AM
regajohn's Avatar
regajohn
Cleaned/detailed, fresh oil change, pump tires to near sidewall max., anti-pest (mouse) measures, fill with non-ethanol gas (if available in your area … pure gas dot org). As mentioned, do not “just start it and let it idle for a couple minutes” … terrible for engines (covered on a couple of the PCA webinars that are available on YouTube … I know it’s in the “fuel and fuel additives” one).
Old Nov 20, 2024 | 02:39 PM
911boy's Avatar
911boy
What anti mouse measure would you suggest?
Old Nov 20, 2024 | 04:55 PM
TD_05's Avatar
TD_05
Wash the car put cover on carefully, don't touch it. I don't buy that a quality cover will cause scratches or swirls.
Old Nov 20, 2024 | 04:58 PM
TD_05's Avatar
TD_05
I have one of those ultrasonic rodent repellers on garage, idk if it makes difference. I've also read that cotton ***** soaked in peppermint extract / oil placed in an old Tupperware container with a few holes in the car or frunk is a good repellant too.
Old Nov 20, 2024 | 05:03 PM
911boy's Avatar
911boy
Thanks. I know they don't like Irish Spring soap. Might put a tub of that under the car.
Old Nov 20, 2024 | 05:43 PM
asellus's Avatar
asellus
unfortunately, the professional detailing community disagrees.
on dark paint I would never recommend or consider using a car cover of any type. white, silver, or similar isn't as big of a deal, since it hides that damage very well.
Old Nov 20, 2024 | 07:37 PM
bmxtreme's Avatar
bmxtreme
LOL, this aint gonna do jack. You'll need to wrap it up to make them avoid you. Fingers cross they don't cross path. Hopefully they aren't running rampant in your garage which is quite unlikely they do unless it's an extremely low traffic garage.
https://www.2cents.my/2021/12/21/pro...-plastic-bags/
Old Nov 21, 2024 | 10:25 AM
911boy's Avatar
911boy
It keeps them away from my cottage in the winter. Car will be in a condo pkg garage.
Old Nov 22, 2024 | 10:21 AM
Kshaw's Avatar
Kshaw
A 25-35 watt solar panel with an MPPT battery controller will do as well as a battery maintainer.
Old Nov 25, 2024 | 05:26 PM
SSFox's Avatar
SSFox
Steel wool inside exhaust pipes
Old Nov 25, 2024 | 07:03 PM
Jim986's Avatar
Jim986
I've always stored my car at my Indy service building . Heated with trickle charger. He's gone so now in an indoor heated condo garage so can't use charger. How long will battery last? Fuel stabilzer and cover....anything else?
why can’t you use your charger in the “heated condo garage?”
Old Nov 25, 2024 | 09:09 PM
DOUGLAP1's Avatar
DOUGLAP1
FYI, the latest issue of "excellence" magazine has a tech note on page 28 about rodent proofing a car using fresh dryer sheets, along with mint, and a product called Victor Scent-Away.
Old Nov 26, 2024 | 10:30 AM
tiiger's Avatar
tiiger
where do they suggest putting these things?
Old Nov 26, 2024 | 11:29 AM
911boy's Avatar
911boy
No place to plug it in.
