HUF TPMS sensors not working
Old Nov 11, 2024 | 06:12 PM
NikosLee's Avatar
NikosLee
Default HUF TPMS sensors not working
hello all,
I purchased new tires for my car and new wheels. I ordered the tires from tire rack and the tpms sensors HUF model appropriate 433 and 315 MHz.
All my previous sensors have worked instantly with the 991 however these refuse.
I have tried driving miles and miles whilst switching from summer to winter, 20 to 19's etc. no luck.
This morning I tried an autel 508 and it could not even get a read.
Shortly after my mechanic, deflted and reinflated and nothing happened.
Is there another tool or is there any other way to check these? I understand they have batteries but your experience and advice would be greatly appreciated.
Old Nov 11, 2024 | 07:07 PM
CSK 911 C4S's Avatar
CSK 911 C4S
Your tire shop should have a hand held scanner to see which one or ones are not working.
I bought 4 for my 991.2 and 2 of them were dead so the system would not reset. Once they replaced the 2 that were not broadcasting the system started working like it should,
What part number did you purchase and what car do you have?
Old Nov 11, 2024 | 07:48 PM
NikosLee's Avatar
NikosLee
Default Scanner
As mentioned we used the Autel scanner and it doesn’t read anything.
Old Nov 12, 2024 | 10:12 AM
barchstein's Avatar
barchstein
Hello,
Im not sure which one you purchased but the ref I purchased was RDE047V21.
They all worked directly and perfectly.
Maybe you need to check the model and that will fix your issue.
(i recall that i was a bit mislead on some site regarding the ref to use... i eventually went with the ref provided by the part search engine of HUF.)
