991.2 display
If you mean 2nd from right, then yes that is a configurable screen and could be matched in any 991.2 (and maybe 991.1j.
Here is a screenshot that shows what you can set the fields to:
guessing they mean second from right.
in the menu, you can select the screens to be displayed. Audio, tire pressure, engine info, trip info, etc... I'm assuming audio stuff is deselected on your menu.
EDIT: wait, that's got stuff beyond audio.
I will backtrack and say, um, I don't know!
Otherwise, the second from the right, the MFD (multi-function display) is set from the steering wheel. Either using the right roller wheel (if you've got the sport steering wheel) or with the control stalk. Lots of things can be changed in that. Which groups are displayed, and on the view shown you can change what's shown on each line, and top/bottom. RTFM for more info.
