Engine shuts off when shifting gears
Old Sep 4, 2024 | 03:10 AM
ASH510's Avatar
ASH510
Default Engine shuts off when shifting gears
Hi,
so I recently purchased a 911 Carrera 2013 PDK
I'm facing an issue with it and until now it is not solved
when I drive for around half an hour or sometimes more and the weather is hot < talking about 45C +
when I stop and shift the gear to R, the engine cuts off directly after releasing the breaks, electricity on the other hand still works
So to make the car starts again I need to shift the gear to P then shut down the car completely and start it again
I have changed the battery after purchasing the car, and a week ago I replaced the front fuel pump as it was diagnosed by a garage that it was old and worn out 🤷🏻‍♀️
but it happened again twice after changing the fuel pump..
This happens with me sometime so from last May until today it happened around 20 times
did this happen with anyone else? And what might be the issue?
Old Sep 4, 2024 | 07:21 AM
Jim986's Avatar
Jim986
Manual or PDK?
Old Sep 4, 2024 | 07:30 AM
Denny Swift's Avatar
Denny Swift
Dunb question, but did you turn off A.S.S.? What happens after it stalls. Do you need to start it again via turning the key?
Old Sep 4, 2024 | 07:32 AM
desmotesta's Avatar
desmotesta
Originally Posted by ASH510
Hi,
I’m facing an issue with it and until now it is not solved
when I stop and shift the gear to R, the engine turns off, electricity on the other hand still works
Manual or PDK?
Does it "turn ooff" the moment you stop or the moment you put it into R/Reverse?
Have you tried turning Auto stop OFF?
Old Sep 4, 2024 | 07:53 AM
ASH510's Avatar
ASH510
Originally Posted by Jim986
Manual or PDK?
PDK
it turns off after i shift it to R and release the breaks
and yes auto stop is off
Old Sep 4, 2024 | 08:16 AM
ASH510's Avatar
ASH510
Originally Posted by desmotesta
Manual or PDK?
PDK
Old Sep 4, 2024 | 08:19 AM
ASH510's Avatar
ASH510
no, system is on
well, when it turns off i need to put the gear to P then turn the key to off then turn it back on again
Old Sep 4, 2024 | 08:47 AM
SilverSFR's Avatar
SilverSFR
Any CEL or error codes present? You will need to scan for error codes with a code reader.
Old Sep 4, 2024 | 10:09 AM
ASH510's Avatar
ASH510
Nothing is showing on the screen and I did check it several times with garages, no error showed in the reports
Old Sep 4, 2024 | 10:29 AM
RennListUser01's Avatar
RennListUser01
Try doing it in S+?
Auto stop/start not turning off?
Old Sep 4, 2024 | 11:07 AM
ASH510's Avatar
ASH510
Originally Posted by RennListUser01
Try doing it in S+?
i didn’t try S+ but i dont think that auto stop is relevant as I closed it before and the same happened
Old Sep 4, 2024 | 11:18 AM
RennListUser01
Closed, as in turned off?
What if it didn't turn off with the switch, but does with S or S+?
Old Sep 4, 2024 | 11:33 AM
Tpup's Avatar
Tpup
I owned a 13 I purchased new. It did what you described except it would just shut off randomly. It did it to me several times and almost got me killed (shut off on the highway in the fast lane and would not restart for 15 mins). I took it to the dealer and they fixed something. I think it was a crank position sensor; once they finally figured that out and fixed it I never had the problem again.. There was a service bulletin about it and several cars were impacted. Search the 991 forum for Crank position sensor and you will find a bunch of threads.
I will say that if it's the crank position sensor it will happen in any gear or in neutral so it may not apply to your car.
Old Sep 4, 2024 | 12:00 PM
baby991's Avatar
baby991
Ok, instead of saying turn on or off, when the light on the button is not illuminated it means the auto start stop function is functioning, therefore you will get engine cut off.
In Sport or Sport Plus mode the Auto Start Stop is automatically activated which means the light on the button is illuminated and you will not get any engine cut off.
So just to make it clear, what is your situation?
Old Sep 4, 2024 | 12:49 PM
ASH510's Avatar
ASH510
