991.2 Headlight Dust inside
Hi All, sorry that the first post is a question.![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
I have dust/ loose specs inside my headlights that we cannot figure out. No moisture ingress even with power washer.
Any thoughts or remedy will be greatly appreciated
2017 991.2 GTS
thanks a stack
c
2017 991.2 GTS
thanks a stack
c
if they are not LED, then there's the whole removable bulb thing that would be a point of ingress. you can access it by removing the fender liner.
