Interior Rear View Mirror Replacement
Look like my rear view mirror UV coating is gone and it's quite hazy - I've searched but could not find a guide on how to remote the mirror to replace it. Suncoast sells OEM replacement. The dealership is quoting over $1K so I think I'm going to do it myself but not sure how hard/easy it is.
Yes - removed mine to have mirror only replaced. Company in Texas. Carefulky remove 2 black plastic covers around post. “Carefully using plastic trim tools . Then remove that fragile ground wire. Next must remove interior black covers these again have several very strong attaching posts. In doing so , the entire mirror housing glued to windshield may come off. No worries but try not. Disconnect wire harness to mirror . Blue connection as i recall. You will know which. To remove mirror and post, twist counter clockwise. It comes completely off. Contact company in Texas to be sure they can repair the electronic night / day which i recall they can. For mine it was an excellent OEM repair.
again in order
1-remove post cover caps - left & right
2- remove interior GPS Cover - 4 strong clips hold . Remove down , then carefully separate
3-disconnect blue plug connection under GPS cover
4-remove lines ( wires)
5- remove mirror - turn anti clockwise as far as it will go. Then pull down.
send and call -
radar - mirror
Frisco Tx
972.571.7427
reassembly isnt simple as it appears
if plate has separated from window , i used very strong 3m double sided tape from napa. Cut small pieces , attached to plate , centering plate then attached to window glass
small ground wire at bottom of post is problematic. Must be exact position for covers to attach firmly.
If trouble reattachng post - push and then clockwise twist , it may become loose after several attempts. Carefully rebend metal clip fingers . “Carefully “
i have manual . If you needed it , even though hard to follow and a few limited pictures .. PM me
cost about $150 or so
again in order
send and call -
radar - mirror
Frisco Tx
972.571.7427
With limited knowledge of your desire , i believe from actual experience with removing and reinstalling your bigger issue will be reinstalling a mirror .. advice .. test it before final installation on the base and secure
