Help understanding my surprise stereo/amp upgrade
About 2 months ago I purchased a 991.2 4S in Florida. I keep finding things that have been done to the car that were not mentioned like the Fabspeed Exhaust. Having owned the car for a couple months, I have been thinking my stereo sounded good, but I was having a problem with spoken voice, like audio books. Thinking no highs, no lows, must be Bose, I knew the easiest way to fix this would be to get some upgraded speakers for the setup I had. While taking the seats out to install some sound deadening in preparation to get different speakers.
Under the driver seat was the following.
I'm not sure how much the prior owner spent on this setup but my guess would be $12-$15,000 installed based on the retail prices of all the individual components.
I don't quite understand how it is setup, so I am hoping that I could get someone who has installed something like this to assist. My question is, with this setup, why do I have a 4 channel and a 6 channel amp with what appears to be all channels used/plugged in? The Focal P60 consists of 7 speakers. That in itself would make sense for the two amps, but you wouldn't use all of the channels. Could it also be powering the factory sub? Any other speakers hiding I don't know about?
I know my next step is to tune/get tuned the DSP. Going to plug it in and see how it is setup in a little bit.
- Nav TV Zen V audio processor
- Moscani one 6|10 DSP
- Moscani Atomo 4
- Figuring there was after market speakers, I took the door card off and found the Focal P60 Limited edition speakers.
I think I figured it out. After plugging it in I was able to test everything. Bunches of problems with how it was set up I found they also replaced the rear speakers which are two of the other channels. Only one unused channel out of 10.
