Non-OEM brakes while covered by Porsche warranty?
Anyone have experience of OPCs stance on using Brembo discs and pads over the OEM ones? Brembo are half the price, but in terms of appearance look very similar.
I could play it safe and just buy Sebro discs and Textar pads, which I believe are actually OEM in all but badging and are also half the price?
I just installed Brembo Ceramic Pads and SHW rotors. While the rotors are great, i might have gotten a bad set of pads. The fronts "RUB" ever so slightly on the rotor and create a ticking noise. I am mechanically inclined so i know its not install related. I could just take the pads out, grab some 300 grit paper and level them out. The pads themselves tho, work just fine. Decent stopped power (But not incredible) and virtually 0 dust, which is what i was after.
I grabbed my kit for front and rear off eeuroparts for $500 shipped, which was a steal.
https://eeuroparts.com/product/shw-p...nce/5053480KIT (seems theyre out of stock on the rears tho)
what are you worried about exactly?
your warranty won't be voided because you didn't use OEM parts. assuming you're in the USA, that's illegal.
the brakes themselves are a wear item. manufacturing defects of a component are covered by the manufacturer. a component wearing out is usually not covered by anyone other than FCP Euro.
welp, then scratch everything I said. No idea!
