Rocker panel dented from VALET ARGHHH
I am curious to know
1. how do you know the valet did it? Did they admit it? Do you see it happen? Or did you only notice it after the fact?
2. very curious how this could have happened. A crease like that in front of the rear tire indicates a direct impact occurring while the car is parked. Something may have hit straight into it like a shopping cart or a bicycle, or most likely another car door especially because it is a clean vertical crease possibly the thin straight edge of a car door. If your car was moving there would be some scrape of the paint from forward or reverse motion. That is clearly an impact dent that occurred when the car was stationary due to lack of paint damage or scraping. While it may have happened while in the possession of a parking valet I doubt it happened with the car in motion. The valet may have been totally unaware it happened. Also since it is so low to the ground on a car that is low, were there any very low exotics parked next to you? I
I watched a expert take a hug concave dent done by a basketball on a Bentley rear quarter. I mean it looked the the kids through the ball as hard as they could at that beautifully rounded shape. The indent looked about two inches deep and the size of the ball. Took him half a day but came out perfect like nothing ever happened....find the right guy, it can be done.
996chi (05-27-2024)
996chi (05-27-2024)
From my experience with dent in a rocker panel on a Porsche back in 2019, the few PDR guys I asked wouldn't touch it. It's not the same as quarter panels/doors.
Ended up having to take it to a body shop.
Sorry OP. This won't be an easy one.
Premium Sponsor
That area is a harder section than the upper portion and it has the texture
although not impossible to repair with PDR, it most likely will need bodywork
the trick is to repair it with exact texture as Porsche, which very few shops can replicate
Seek out the best Porsche specialist in your area and go check out their work before repairing
good luck and let us know how it turns out
I know sign painters who can match this texture. it's just application technique, most of which is twisting the right ***** on the paint gun.
mm, pump the brakes there. any bodyshop worth going to will be able to match the texture without issue. under-paint chip guard coatings have been around for decades. even Mazda has been doing it since at least the 80s, it is by no means exotic.
MoeMistry (05-25-2024)
Premium Sponsor
it is very difficult to replicate, but can be done if painter knows how
Specializing in Porsche/Ferrari since 1995
Why choose GP...WATCH OUR DOCUMENTARY
Follow Moe HERE
GP Fastrak - Ceramic/PPF/Tint in one simple bundle - Click Here for more info
Follow Moe HERE
yeah I'm aware of what you're referring to. that texture is caused by a layer of under-paint chip guard, and its texture is dictated by the nozzle size, fan configuration, and of course feed volume.
it's not special on porsches, it's not exotic, and it's not difficult to do. putting the idea out there that it requires a special shop to perform this is misleading at best. 3m even has publicly available videos explaining how to achieve various textures, and tips for how to speed up that process.
the texture has little to do with the level of protection offered. the protection is due to the elasticity of the coating.
shammerman (05-25-2024)
