991.2 S PDK Turbo Lag from a dig?
Here you go. Took a quick video from a stop sign. When I say go, that’s when I slammed the pedal to the floor. Notice the lag from 2500-3000 rpm. My question was if this pause is normal? Car was in sport mode.
Thanks.
https://youtube.com/shorts/IIWhKzc6P...USfHRK3YacnWc6
Thanks.
Tire spin and TC kicking in?
Thanks.
Thanks.
The following 2 users liked this post by asellus:
Cityfisher (04-27-2024),
thesaintusa (04-27-2024)
9Gyarah (04-30-2024)
If you plotted your acceleration you would see you are already accelerating while the RPM's "hang" there for a second, its no different than slipping the clutch when launching a manual car or the torque converter slipping when launching an automatic.
Don't worry about it, if the transmission didn't do this and it just dropped the clutch you would either stall and bog the engine or spin your tires.
If you want an even better launch go into sport + hold the brake with your left foot and slam the gas pedal with your right foot all the way until you feel the kickdown switch. This engages launch control and will hold the RPM's even higher to generate more torque.
