Problem with PDK?
Hi there!
I have recently purchased a 2014 991.1 4S automatic and after a few miles, I encountered a problem. When I fully kick down the gas pedal (until maximum and also right before the kick-down), the PDK does not shift past the 3rd gear. It keeps revving around 5000 revs. I have to lift my foot from the gas pedal and eventually the revs lower and the PDK shifts again. This happens in normal mode, I have not tested it in sport or sport plus yet. When I drive more behaved, that is without pushing down the gas pedal too much, the car behaves normally.
I have also tested manual shifting during kick-down in manual mode. Shifting from 3rd to 4th gear here also does not work properly, it seems to be stuttering and eventually shifts after lifting my foot. In manual this also happens at lower revs and only with max / almost max throttle.
The problem did not appear during the test drive pre-purchase. Although I did not test this extensively.
Does anyone have an idea about what this could be? Is there a possibility for an easy fix or could this mean PDK replacement? The car will go back to the dealer soon as it is (luckily) under warranty. Any input beforehand about what the problem could be would be appreciated.
Thank you in advance.
I'm not sure this is weird or a problem but maybe I misunderstand. If you are applying nearly full throttle I would expect it not to shift until late, even in normal mode. Will it shift if you pull the right paddle?
The car does not shift past 3rd gear and keeps revving in 3rd gear at around 5000rpm. This happens when I fully push down the gas pedal, but also when I push down the gas pedal until right before the kick-down. Maybe also at less throttle than right before the kick-down, but I have not tested that yet. Hope this is more clear.
If you think that is weird, try doing it in sport plus. You won't shift out of 1st gear until near redline.
cbredesen (04-14-2024)
RobC4sX51 (04-14-2024)
Nashvegas (04-17-2024)
Exactly. If you are pushing the car, the PDK thinks you are in a mode demanding max power to the wheel. Even when lifting the revs stay up expecting more. Eventually when lifted the car settles down.
Hi All, thank you for your input so far.
Maybe I did not explain it properly. The car did not accelerate further and stayed at 5000rpm. I was still pushing down the pedal. The car was revving at 5000rpm and did not accelerate. Like there was a limit it was hitting. This happened 4 times in a row. The car did only accelerate further and shift once I released the gas pedal and pushed the throttle more gently.
Today, I was at the mechanic (Porsche specialist where I bought the car) but we could not reproduce the issue. Which is very weird. There are no error codes to be found according to the mechanic and they don't know what the issue could be.
I am a bit worried that this is an issue with a slowly dying PDK or something else, and there will be a dramatic and expensive failure after the warranty.
Maybe I did not explain it properly. The car did not accelerate further and was revving at 5000rpm. I was still pushing max or almost max throttle. It was like the car was hitting a limiter. The car should have either accelerated further and increased rpm until redline, or shift and accelerate. This happened 4 times in a row, in automatic and also in manual mode while shifting using the shifting pedals.
Very weird indeed. Today I was at the mechanic and we could not reproduce the issue. There are also no error codes to be found.
I am a bit worried that this issue is due to a slowly dying PDK or something else, and will result in a catastrophic failure later on after the warranty.
I'd have the PDK reset via a dealer computer.
I hope this is a CPO car?
