PSE Rattle @ Idle / Low RPM
Just upgraded stock exhaust to PSE on a 991.1 C2S. I have about 2k miles on the new exhaust and notice a rather tinny rattle at low rpm and idling. It does not happen all the time and I can get it to rattle with the valves open and closed. Any one ever experience the same or have any ideas?
I believe I have the same issue and it's starting to get on my nerves. Now that you mention it, it doesn't happen all the time (even at cold start) which is bizarre.
I stuck my head under the rear and hit a bunch of things with a rubber mallet to see if there were any obvious rattles but didn't see anything.
I'm unsure if it's PSE, the headers/cats, or the muffler. I'll be changing out the header/cats hopefully in the next month (or so) and will be paying attention to whether that fixes it.
Just wanted to follow-up for anyone following this thread. I just came back from local shop and had them check the rattle. The found the PSE exhaust tips and cover had become loose. Tightened down and rattle gone!!
The following 2 users liked this post by jm82911:
CSK 911 C4S (08-13-2024),
slowrey (08-13-2024)
I need to take mine in for I think the same rattle. It's either the exhaust or one of the heatshields somewhere.
