Sprint booster
Sprint booster
I've seen some post about sprint booster and thought it might be a nice upgrade for the cost on a 991.1S. I know it's not adding any power so I want to be clear about that but I find that the throttle really needs to be punched to get the car up to power band. From the comments I think that the change in throttle blade opening could make the car more fun when driving around. If anyone has used one I'd appreciate your opinion.
Did it make the car more fun to drive? Yes or No.
Again, I know it doesn't help the car produce anymore power but I think it may change the way the car feels while accelerating especially when just driving in spirited mode not pedel to the floor mode.
Yes. It makes the throttle more sensitive, more touchy. I've got one in my 991.1 C2S and you can absolutely, 100% feel the difference and it makes the car more fun to drive. I've got the Pedal Commander because I like the app that goes on your phone. You can adjust all the settings with the app.
Now, prepare for naysayers............
Cayman Ed (02-24-2024)
If you have read the other threads, you have you answer. Adds another dimension to the car, much more fun, quicker response. Car wants to go!
From what I understand, all it does it change the slope of the accelerator curve. It doesn't magically find/add power anywhere. So the amount of throttle applied at any given input angle of the pedal gets raised above the factory's chosen level. I've not seen the actual curves the different modes apply.
I had a Sprint Booster in my '17 Cayenne and it did improve off-the-line accelerator action from a dead stop, as the default tended to not spin up the torque converter as effectively as I'd have liked. I seem to recall using a 4 or 5 on the setting for it. The downside to this meant that highway inputs were also dialed up, making for a twitchier pedal when you were at speed. Like anything, you 'get used to it' but it did make for a bit more unexpectedly aggressive throttle on the highway. The module does not adjust itself based on vehicle speed. It's be *great* if that was possible but it isn't, at least not in any of the modules I've seen them promote.
I don't find the accelerator action on my '18 Targa to need the Sprint Booster.
