Battery Question
I've read a number of the threads on battery size and replacement, but have not found the answer I am looking for. Is the OEM battery (991.2, PN 999.611.080.12) a standard lead acid battery or an AGM battery? The owners manual indicates to only replace with a comparable AGM, so I am assuming that it is an AGM, but there is not anything definitive printed onn the battery case (its the original Banner). The reason I ask is that I am connecting a new CTEK charger and I want to select the proper charging mode.
Thanks - Bill
Thanks - Bill
