AWD front driveshaft delete?
Old 02-09-2024, 04:38 PM
flsupraguy
flsupraguy's Avatar
Received 1,459 Likes on 784 Posts
Default AWD front driveshaft delete?
Has anyone deleted the front wheel drive system on their carrera 4/gts?
Old 02-09-2024, 04:47 PM
Joec500
Joec500's Avatar
Def a common thing with 997's and even Lambo's and R8's. I am curious how the stability control would take it.
Would love to hear of anyone that has done this.
Old 02-09-2024, 05:37 PM
asellus
asellus's Avatar
Received 1,942 Likes on 1,204 Posts
I've heard of it done on 997s, but not 991s yet.
I'm sure it can be done. There are a lot of options in the coding revolving around things like "is this vehicle equipped with awd" or "is there a sunroof" and whatnot. While I doubt it, there's a chance it might be as simple as flipping one of those bits.
Old 02-09-2024, 06:16 PM
myrr
myrr's Avatar
I didn't know people did this - interesting stuff! Assuming it's mostly weight savings and increased fun factor?
Old 02-09-2024, 06:22 PM
rensoyka
rensoyka's Avatar
pay more for a C4 and then make it into a C2? well okay then.
The following 4 users liked this post by rensoyka:
Cityfisher (02-28-2024), CSK 911 C4S (02-16-2024), detansinn (02-11-2024), shammerman (02-09-2024)
Old 02-09-2024, 08:18 PM
asellus
asellus's Avatar
the only guy I know that did this was to become competitive in PCA racing.
... and this is the point that always confused the hell out of me. it would have been cheaper to sell, buy, and prep a C2 over converting a C4.
there's the whole widebody/narrowbody thing I suppose? there's no widebody C2 non-S, right?
Old 02-09-2024, 10:00 PM
Speed2k
Speed2k's Avatar
Afaik, only in GTS form
Old 02-09-2024, 10:41 PM
Catharpin
Catharpin's Avatar
Yep, which is C2S X51 in WB with some extra GT/Turbo bits and unique features.
The only way to get a 3.4 wide body is C4. So the to get a C2 wide body would require what is being asked here.
I don't really see it making sense on an operational GTS used on the street, when you can just buy one in RWD and save the hassle/depreciation involved.
I suppose for a rebuild/track car it might make sense.
Either way, it would be interesting knowledge to have and understand.
Old 02-10-2024, 10:59 AM
Jim M.
Jim M.'s Avatar
My son did it to his 993TT. He claimed was for track duty and was pleased with the outcome. I drove the car in anger when it was four wheel drive and was very impressed. Never drove it in anger after the mods. Quite frankly it never made sense to me, but I was never a ttack rat.
Old 02-10-2024, 11:07 AM
subshooter
subshooter's Avatar
Received 2,161 Likes on 994 Posts
I only bought my C4 for the wide body look. I didn't need AWD or the extra weight. I don't think I would ever consider deleting he AWD system though.
Old 02-10-2024, 01:51 PM
rensoyka
rensoyka's Avatar
last time I checked it's less than an inch on each side.
dannyk304 (02-12-2024)
Old 02-10-2024, 04:58 PM
Guards_Red_991
Guards_Red_991's Avatar
That's what she said...
Old 02-10-2024, 10:34 PM
4 Point 0
4 Point 0's Avatar
Received 1,200 Likes on 636 Posts
I think there very well may be something like that.
I have a RWD GTS. 991.2. They come with that silly E-Diff. Whilst it is an LSD, its computer controlled with oil.
I was at the track and things were heating up, and suddenly I got a “Front Diff Failure” error message on the dash.
I laughed. Pitted and switched car off and back on again, and it was gone and it has never happened again since.
Being RWD I clearly have no front diff to fail. But the system clearly thinks its an option.
When E-diff gets hot, it stops locking. So I have replaced it with a Full mechanical, OS Giken LSD. Zero issues since. Locks on command.
Old 02-20-2024, 11:59 PM
ihatelemoncpo
3rd Gear
ihatelemoncpo's Avatar
maybe unrelated but looking for some help here myself...noticed car had grease spilling out of driver front axle on 2017 C4S and had a clunking noise so I took the car to a reputable shop and they tell me I need front differential and both front axles replaced....NOT CHEAP, parts close to $7500. The car just reached 60k miles and sees about 4 track events a year since around 40k miles. Also been to a few drag strip events and launch the car for fun regularly. The car has GTS turbos with a tune so it makes significantly more power than stock along with PDK tune. The only suspension related work I have is Bilstein B16 coilovers and camber plates with -2.9 degrees camber up front.
Given the cost of this job, really hoping I can convert to C2. Any thoughts? Is this to be expected with a car that sees track time? I have never done differential maintenance, only engine and PDK service. Thank you in advance.
Old 02-21-2024, 07:58 PM
rwbern
rwbern's Avatar
Not sure I understand why anyone would do this other than track use.
Quick Reply: AWD front driveshaft delete?
