Can't figure out the dreaded Coolant System Error
2nd Gear
I've got a '13 c2S with about 60k miles on it. First time I got the error message it turned out to be a bad changeover valve, had it replaced no problem. After about another 1k miles, I now have another Coolant System Error message, this time they're seemingly having a lot more trouble pinpointing the problem and I've been told it's related to a vacuum line. They can't identify exactly where a vacuum line has come loose or frayed to throw this error. So today they told me the next step would be to dive deeper to inspect / replace all of the vacuum lines, and quoted me around $1800 give or take depending on where the issue lies.
I should also note, about 300 miles ago I had a Fabspeed Valvetronic Exhaust System installed. I figured this had to be the problem but they say it has nothing to do with that and everything looks fine in that regard. I think this cost seems absurd compared to other scenarios I've read about on these forums, especially considering its not a giving a bad COV reading. I'm very interested to hear others' thoughts. Has anyone else experienced anything like this? What was your solution?
2nd Gear
The exhaust button works - mind you- my car didn't have the PSE button, but with the fabspeed valvetronic I have a separate system on my keyring to open/close the valve. Works just fine. The heat works, Brake pedal feels normal. Car isn't running hot at all. Not sure about the symposer, how does one even know if it's working or not? Will look into the vacuum pump.
I would start with plugging the 2 that are easiest to reach and the most useless, the air cleaner flap and acoustic simulator. After that move on to the others. Here is a good post showing locations. https://rennlist.com/forums/991/8002...l#post13043586
And if I were to replace vacuum lines, I'd do it myself using silicone tubing with a Durometer so that they cannot collapse during vacuum. Those lines last forever and can take heat.
