Barking dog sound at idle 991.1 C4s new video link
I am 99% sure this is caused by your throttle body/valve. I had the same issue when I bought my 991.1, it was always associated with a slight roughness in idle as well. I tried chasing the idle stability with various changes, even asked a shop to listen to the noise as the momentary roughness in idle always went along with the noise similar to yours, and no one had anything of value to add. A year later I stumbled on a post somewhere complaining about a similar noise (they called it a frog - and mine sounded more frog-like as well) and changed my TB and low and behold, the noise completely gone and idle rock steady ever since - a year on now and no issues. Good news, it's under $200 From FCP Euro if you buy the Bosche OEM product and it was very easy to install in my garage. Good luck and if you do it please confirm this worked.
Will let you know how it goes, thanks again.
I changed plugs, coils, PCV hose (that had slight crack, VVT solenoids, MAF, camshaft position sensors, air filters, and other things all to no avail. This TB change was magnificent for me.Good luck and let me know if you need any info on changing it. was rather easy compared to the other things.
ive had a new belt and tensioner during its 6 year service, I guess once I pull the bumper off I’ll hear the noise up close
amazing thanks
Very interesting. I occasionally hear that noise from my 2016 GTS when I'm back in the garage after a drive on a warm day. I thought it might be emission control related but haven't yet investigated it. I do see from a couple of parts websites that the throttle body part number may not fit the GTS. Other sites say it does fit.
