Rear Tail Light Illumination
Old Dec 6, 2023 | 06:23 PM
FrankMax's Avatar
FrankMax
Default Rear Tail Light Illumination
Hello. I have a 2017 C4S and am getting Message Center notices that my right rear and left rear tail lights are out. I'm a new owner and don't know how they're supposed to look. With the car running and lights on auto, the single row light is illuminated across both rear lights and through the center, so one long strip. Flashers will illuminate 4 small LEDs, in a rectangular pattern, on both of the rear lights. Thank you in advance for your help. Frank
Old Dec 6, 2023 | 08:11 PM
arter's Avatar
arter
Try the brake lights ( they use the 4 small LEDs plus the third light bar higher on the car.).
Its possible that someone removed the rear bumper to do work and didnt get a electrical connector tight enough given both sides are out at the sqame time..
Old Dec 6, 2023 | 08:28 PM
FrankMax's Avatar
FrankMax
Thank you! Just tried the brake lights and they operate as you described, with the extra 8 total LEDs lighting up plus the high center. While doing that test, the error message still popped up.
Old Dec 6, 2023 | 11:01 PM
docskeet's Avatar
docskeet
Is the battery the original? As the battery fails, electrical gremlins are not uncommon.
Old Dec 6, 2023 | 11:08 PM
FrankMax's Avatar
FrankMax
I believe the battery to be original. Do you think the rear lights are functioning correctly as described? Is it correct that only the one horizontal "bar" through both rears and center are the only rear lights activated while driving with light switch set to Auto? Thanks!
Old Dec 7, 2023 | 12:07 PM
arter's Avatar
arter
yeap thats what I see on my car.
put it in reverse and see if the white lights come on.
Old Dec 7, 2023 | 12:33 PM
FrankMax's Avatar
FrankMax
Thanks and yes, my reverse lights are working.
Old Dec 7, 2023 | 12:47 PM
T3X4S's Avatar
T3X4S
Battery is going out. I had 6 year-old original battery on battery maintainer. I got the same rear light faults on my targa for a few weeks. I even double checked the lights which were on and worked fine with and without brakes activated. Then more faults popped up including RAS faults. Finally. the car struggled to even start, and I was almost stranded at a restaurant. No issues after I put in a new battery.
Old Dec 7, 2023 | 01:03 PM
FrankMax's Avatar
FrankMax
Thanks so much and I'll work on getting one. Do you think I can order an appropriate AGM battery at AutoZone?
Old Dec 7, 2023 | 01:04 PM
FrankMax's Avatar
FrankMax
Old Dec 7, 2023 | 01:16 PM
MikeL31's Avatar
MikeL31
Costco has the best price. for an Interstate AGM its $169.99.
Old Dec 7, 2023 | 01:35 PM
FrankMax's Avatar
FrankMax
Thank you! Since I live in the boonies, the nearest Costco is 80 miles away. I'll give AutoZone a try. Thanks again!
Old Dec 7, 2023 | 01:57 PM
MikeL31's Avatar
MikeL31
My battery took a crap on me while I was out recently in my truck. Not wanting to be stranded, I just bought a duralast agm at autozone and installed it in the parking lot. Expect to pay $90-100 more for a duralast agm, similar warranty.
Old Dec 7, 2023 | 03:53 PM
FrankMax's Avatar
FrankMax
I just picked up an H7 Duralast Platinum AGM at AutoZone for $250. I hope that fixes my rear tail lights that aren't broken
