Reliability: 991.1 vs 991.2
Not speaking from experience but from looking at informative YouTube videos of so-called experts, it is best done by removing the oil pan and looking at the base of each cylinder when the pistons are at the top. They also say it is most likely on cylinders 5 and 6.
Where you using your 991.1 as a daily with short commutes and also in the winter? There is a chap who had bore scoring on a 997.2 TT - car was dailyed even in winter with no oil change in winter (but car had its annual oil change). Engine was eventually replaced...
Do you have pictures of what scoring looks like?
Yea ill upload a couple pics
If you google 9A1 bore scoring you will see this is a thing, not super common, but is a thing for sure.
Here some good info, the first pic you can see the lines going up to the top of the cylinder.
https://lnengineering.com/products/w...1.html?limit=8
Pics
These are top of piston, see those shiny scratch like marks? Not sure what scratched it, air filters were always clean, oil reports never showed any signs of intake contamination
Here’s a couple of cylinder walls, see those long shiny lines that are running up down cylinder. 4 of
the cylinders had none of this.
