Steering wheel persistently off center to the right
Hi all
Have a bit of a frustrating issue. Steering wheel on my 991.1 carerra S favors the right buy a few degrees, consistently turns clockwise going over bumps. Seems easier to turn right than left. 3 dealer alignments, including a road test has not fixed it. On the last one they adjusted the tie rods, now the car pulls more to the left but the steering wheel remains essentially unchanged. Took it back since I did not have confidence that they would spend the time to fix it. Alignment printouts seem fine. Newish tires (<2000 miles), pressures all good. Unclear if this was happening before new tires as I put them on when i bought the car about 2 years ago.
Car otherwise is perfect.
Looking for any ideas. Any recommendations for a shop that can get this right in the Boston or greater Boston area would also be appreciated, with a very high attention to detail and will actually road test the car before and after.
Thanks for any help
Thanks for any help
drive in the left lane of a divided highway or similar road where the entire paved surface is dedicated to going one direction. does that change the behaviour? if so, it's just the crown of the road.
otherwise, I would recommend not going to the dealership for anything that isn't warranty work -- that is, unless you like setting money on fire. the 911 is not special and does not require a dealership technician to work on, especially for alignments. paying more than $120-180 is absolutely criminal for aligning these cars.
the steering wheel being centered is one of the basic steps of an alignment, so it's kind of bizarre that you've had multiple alignments done and the steering wheel has remained off-center. that says to me that they put it on the rack, saw everything was in the green (which is a huge range, by the way), and said "yep it's good" and gave it back to you. very common thing to do, especially in volume shops.
if you want to try for another alignment, go to a race shop and get an alignment. mention the symptoms you're trying to get rid of. they'll check the applicable parts to make sure they are good and then perform an alignment.
If I understand your post correctly,the steering wheel is straight if you go on a smooth road in the middle lane with no crown left or right,correct? It just favors one side...
The wheel returning to center is a caster adjustment : I'm not an alignment guy,don't even know if caster is adjustable on that car...
Try finding a good race shop that does alignments on these type of cars : they will check for loose parts and perform a better alignment than the dealer.
My steering wheel was not centered correctly after my last alignment. Alignment was perfect but the wheel didn't sit at 12 o'clock when going down a straight smooth road. Took it back and they had the steering wheel adjusted in 5 minutes and has been perfect ever since.
What tires are you running?
I'd swap the front tires around and see if the car then favors the left side vs the right.
Could be a bad tire.
