Seat back adjust switch not working. manual adjust.
I have a failed seat back angle adjust switch. Is there any way to manually adjust the seat back?
If you or a buddy has a two-way scan tool (like an autel mx808, ms906, launch x431, snapon somethingoranother) there might be the ability to go into live functions for the seat memory or body control module and command the appropriate movement. I'm sure if you took the seat out completely and flipped it over there's a screw or shaft you could twist or something.
