991.2 keeps randomly overheating
#31
towed car to dealer week ago,they called and are going to replace waterpump again(2nd replacement) and the valve block, etc..no mention of $$$ so Im guessing that 10 year warranty is kicking in and they are going to have it delivered to my house which is 1 hour away. Hope that cures it.
So it turns out, when these water pumps start to go, they can be quite intermittent and unclear to immediately diagnose - similar to your situation too - but eventually it becomes obvious. But glad it seems to be fixed now.
#32
If your adding coolant where is it going? Has Porsche tested the coolant system for exhaust gases? A blown head gasket would cause the coolant system to become entrained with air, think a very small leak. Water pump is vacuum operated on 991.2, if you want there is a 90 degree vacuum hose right below the water pump. Unplug it, does coolant pour out, there should be zero. This is a solvable problem, it appears the super qualified special citizen porshe technicians missed a programming session......
Just out of curiousity, Is this the 90 degree vacuum hose you are talking about? pic just for reference: https://cimg0.ibsrv.net/gimg/rennlis...c9c79e6c1.jpeg
If coolant pours out, then what would be the diagnosis?
