Installed Rennline Pedals, Wind Buffeter pieces, Carbon door pieces, & OEM outter sil
Hello there!
I probably should create my own thread for the weekly mods I'm doing, but thought I'd share what I did today. As the title mentioned, I installed Rennline Pedals, Wind Buffet pieces, Carbon door pieces, and an OEM outter door sill for the passenger side.
Since my 991.2 is from 2018, I've slowly began replacing the parts of the car that have showed 'aging'. Below are pictures of what I accomplished today!
The car I'm working with!
Got a couple of seat belt samples in.
I'm 100% going with Miami Blue! This will be a project this fall.
Ordered an OEM Miami Blue entry fob from eBay to match the calipers. Obviously a perfect fitment & zero issues.
Before shot of the door handle inserts!
Rennline carbon fiber inserts ($150) installed. Literally a 10 second installation & perfect fitment!
911 Pedals
Masking off brake pedal for drilling
Started with a 1/16th drill bit and worked my way up to the recommended solution on the instructions. It's very easy to do, but use painters tape like I showed in the previous photo to make sure the Rennline pedal completely covers the OEM pedal. Once drilled as show above, installation is very straight forward.
All installed! This took about an hour taking my time & making sure everything was aligned
Just a car shot after I did everything!
Time to replace the outter door sill on the passenger side. I already did the driver side 4 or 5 weeks ago.
Sill removed. This 3m glue is a major pain.
45 minutes later!
All of the 3m glue was removed & I put on the new sill from Suncoast!
911 Pedals
45 minutes later!
You do nice work.
BotterBuilder (07-18-2023)
I've been wanting to change my seatbelt color for awhile now and just haven't had the ***** to dig into it yet. I know there are one or two YouTube videos about it but just not sure I want to dig into it.....LOL,
Nice job, looks great. The seatbelts will look awesome.
in love with your red interior btw 😍
stevekish1 (07-23-2023)
