Engine Noise
Engine Noise
Hi Guys,
Just purchased my first 911, 2013 85k miles, base, PDK. Quick question about engine noise:
When I rev out the car (under load, never tried in neutral), there is a distinct change in sound starting at 7,000 RPM that then goes away when the PDK shifts. I would say it sounds like a straight cut gear/whining noise.
Everything sounds perfectly normal to me in all other cirmcumstances. Car has a documented maintenance history, just had the 80k service done this spring. PDK service is coming due and i plan to have that dealt with this summer or fall.
Just want to know if this is normal/expected, a known issue, or an i'm screwed situation.
Thanks in advance!
Thanks in advance!
Try to record the sound. It's going to be hard to weigh in otherwise. There is not normally a distinct change in pitch at 7k RPM but it could be a harmless vibration from something being a bit loose on the chassis.
Seems like leaving the phone on the parcel shelf may be the ticket for this one.
