Headlight beam adjuster fault info
Old Jun 29, 2023 | 06:48 PM
dewdrop's Avatar
dewdrop
Default Headlight beam adjuster fault info
Had just bought my 2012 911 S and loving it. After 2 weeks of fun I started it and got the “Headlight beam adjuster fault”. Every time I started it. The headlights did “wink” properly when started and the 4 level sensors were attached properly on the suspension. So what was the issue?. Took it to dealer and the left headlight needed recalibration! That was all and now no more warning. Hopefully this solved it for good. Just passing this info on to others.
