991.2 Sport Chrono/Chassis Question
I'm a little confused by the shock absorber icon button in my 991.2 GTS. Can anyone answer this question? When you select the various Sport Chrono modes, those settings change the suspension Normal = softer, sport = stiffer. sport plus = stiffest. When I engage the shock absorber button on the console it activates the sport chassis. Is this redundant? Is this separate from the suspension changes that occur when selecting the Chrono modes? The console button only lights up when activated and does not when chrono modes are changed. I would assume the sport chassis is in effect in sport or sport plus modes even though this button does not light up. Of course the spoiler button does not light up when the the spoiler automatically deploys so I'm not sure about the chassis button. Also, since my individual mode is programmed for the sport power train program, and exhaust, I have it with the normal driving suspension for comfort for the road conditions and daily speeds . I use the sport chassis button on occasion when in my individual mode using normal suspension, should I be on good asphalt, or sweeping turns or transition ramps at speed for example. It this the function of the separate chassis button? Anybody shed some light?
I appreciate the read the instructions tip, which I did of course. Looking at the page where the chassis graph was a little confusing as there appear to be three settings, normal, sport and sport chassis. Also I wanted to clarify if the shock absorber/chassis button overrides the chrono settings. I admit to being confused by chassis management and suspension management. I get how suspension changes, but what changes on the chassis? Forgive the ignorance but I didn't asking for some clarification would be a nuisance.
I have a 2017 C2S which I purchased as a CPO vehicle from the dealership who originally sold the vehicle. And have the same pages in my owners manual. I will have to check again the next time I drive my car to see if rotating the little black **** at 4 O'Clock offset to the steering wheel hub from Normal to Sport and to Sport Plus changes those LED lamps in the buttons on the center console. I thought they did light up when activated via the rotary ****.
However, I've learned via experience and trying various systems and functions that per the build sheet and hardware are on my car that not everything in the owners manual edition for USA [and Canada] functions as described in the owners manual. For example, Sport Chrono features are a glaring example of several exceptions. The mapping and additional optional for recording lapping data functions do not function, and of course, do are not available to play back on the PCM display screen. The only data available to retrieve from the records is lap time for each lap -- provided that you have remembered to push the "Round" button on each successive lap as you pass the start/finish line or some other track marker you choose to use.
And why did Porsche install a button on a stalk to push for voice commands and not include that feature in its otherwise rather comprehensive PCM and NAV system? The dealer says that the required electronic module had to be installed at the factory and cannot be added at the dealership. But the PCM knows that you pushed the button and when you do, it displays a message that the function is not available.
I haven't figured out how to use the Chrono function in PCM as it pertains to lap timing. It would be cool if it integrated with Porsche Track Precision app.
Porsche Active Suspension Management, PASM and Porsche Dynamic Chassis Control, PDCC - 2 different systems.
PASM is an active system. It may be turned on due to the SC S+ setting or by the PASM button. If you select S+, the PASM button light should turn on. But I think it PASM active all the time.
Porsche chassis development
Dynamic training 2016
Press kit
Basis of the balanced chassis: Active PASM shock-absorber system
One of the first active chassis systems that Porsche implemented and is still continuously developing
is the Porsche Active Suspension Management, or PASM for short. This combines two
chassis in one: a sporty yet comfortable chassis for long journeys and an exceptionally sporty
chassis for the race track. The normal setting provides a more comfortable basic configuration
of the dampers, and switches to a more sporty mode if the vehicle is driven more dynamically.
This increases comfort levels, particularly long motorway journeys, as the PASM absorbs minor
to moderate bumps in the road surface significantly better than a standard passive chassis. In
contrast, the sport setting activates harder damper characteristics that support a highly agile
driving style. The reduced car body movements make it easier to achieve fast lap times on the
race track.
The PASM responds in a flash to dynamic changes during driving. For example, the system increases
damper force to both axles in the event of sudden steering movements, e.g. during unexpected
manoeuvres to avoid an obstacle. This reduces lateral inclination or instability of the
body and makes it significantly easier to control the vehicle, particularly in extreme situations.
In normal mode, the damper force is increased if the vertical movement of the body exceeds a
certain value, for example when driving over bumps in the road surface. This reliably prevents
instability of the vehicle body. In contrast, sport mode slightly reduces the damper force as car
body movements increase to improve contact between the wheels and the road. This prevents
any jumping or displacement of the car, while at the same time noticeably improving comfort. In
normal mode, depending on the vehicle speed and lateral acceleration, the damper force is set
differently for the inner side and outer side of the vehicle when cornering. This prevents vehicle
instability and significantly increases driving precision. The damper characteristics are adjusted
individually for the front and rear axle during heavy acceleration, during gear changes and when
the accelerator pedal is released.
Press kit
race track.
Some more info.
Press kit
race track.
Press kit
race track.
Ditto for me on many of the roads in NE Ohio and western PA. My car is also a 2017 C2S with PDK, Sport Package and RWD. The stiffer damper settings are too stiff for many roads. Compliance -- allowing the springs to do their work together with effective damping is much preferable to me.
