Wheel center cap REMOVAL
Old 06-10-2023 | 12:05 PM
dak911's Avatar
dak911
Default Wheel center cap REMOVAL
OK what's the secret to removing the wheel center caps....IIRC there "used to be" 2 little holes in them that were removed with the PORSCHE SPECIAL TOOL # ......... (or a bent wire)
But there are no holes in the "new" caps......
You "KNOW" that a judge will take off points for this "infraction" of the emblem not pointing to the valve stem
Old 06-11-2023 | 09:23 AM
TRM's Avatar
TRM
If you have a GTS with Center Locks...The little tool specifically for this under the Frunk.
Lift off the plastic cover that is just aft of the cargo area. There you will see a cylindrical plastic container right of center. Take off the cap and inside is the wheel nut removal tool, and inside that is a small plastic tool you use to pry where there is a little notch in the center cap.
I don't recall where this little tool is kept in my 2014 S. Sorry.
https://www.pelicanparts.com/More_In...%20Catch%20All
Old 06-11-2023 | 10:17 AM
Porsche_nuts's Avatar
Porsche_nuts
you can take off wheel and push it out from the back of the wheel
Old 06-11-2023 | 12:46 PM
dak911's Avatar
dak911
Uh Huh... I figured that out Just a bit extreme don't cha' think !!
Old 06-11-2023 | 01:46 PM
barncobob's Avatar
barncobob
UMM, thats how it works
Old 06-11-2023 | 01:50 PM
ddolbi's Avatar
ddolbi
Try suction cup like this Try suction cup like this
Old 06-11-2023 | 02:11 PM
barncobob's Avatar
barncobob
Originally Posted by ddolbi
those things suck
Old 06-11-2023 | 02:41 PM
dak911's Avatar
dak911
OK I guess there is no "hack" (easy way)
Unless the person who does the tire changes is a P car person...they don't have a clue about the emblem orientation.....
Old 06-11-2023 | 08:56 PM
DBH's Avatar
DBH
Mine were properly aligned when delivered by the dealer. BTW, both my '18 991.2 and '22 Macan have the little removal holes in the center caps. They're located in the black colored stripes and may be a bit hard to see.
dak911 (06-12-2023)
Old 06-12-2023 | 04:46 PM
dak911's Avatar
dak911
OK I feel like a "complete" Idiot...Porsche has done such a good job of hiding the little "holes" that I didn't even see them I guess I can just use a bent wire to pop them off
Old 06-12-2023 | 05:15 PM
MingusDew's Avatar
MingusDew
https://www.suncoastparts.com/product/00072192291.html
Like this, right?
Old 06-12-2023 | 07:04 PM
Catharpin's Avatar
Catharpin
Originally Posted by MingusDew
Wow, $42.50 for a bent wire? I guess that is inline with the $40 pigtail "wiring harness" to adapt the redesigned COV. Porsche tax in full effect here!
Old 06-12-2023 | 08:03 PM
dak911's Avatar
dak911
I used a piece of bent coat hanger $0.00 And IIRC MANY years ago there was a small version of that "puller" in the tool pouch
Old 06-12-2023 | 08:07 PM
barncobob's Avatar
barncobob
its not a dental instrument...
dak911 (06-12-2023)
Quick Reply: Wheel center cap REMOVAL
