GTS rear diffuser
GTS rear diffuser
Does anybody know if the rear diffuser for a 991.2 GTS with sport exhaust is different in size than the base 991.2 with sport exhaust? Fabspeed sells a carbon fiber diffuser and it is labeled for the GTS. I asked them and they said it will fit my base 991.2. I just wanted to make sure. They also sell one that is labeled that it's for the base but that one doesn't have the center carbon piece whereas the GTS one does which is why i want that one. I know the GTS is a widebody so that's why I wanted to double check. Thanks in advance.
I presume no one knows since I haven't gotten any replies. Can someone who owns a GTS with sport exhaust measure the length of their rear diffuser from one end to the other?
I have 48.5" across the bottom side (under the car) measured from where body color meets black. I wouldn't quote this as super exact but if the narrow body piece is different my guess is it'll be more than like 1/4" different.
I don’t know if this helps of not, but I have a GTS. I replaced the stock piece with an Akrapovic diffuser. It fit perfectly. There is only one size in Akropovic. If anyone who had a narrow body has fitted an Akra Diffuser then that would make them the same.
On a coat basis, I would think the centres would be the same, and just the coloured bit of the bumper different from wide to narrow. But I’m just guessing.
