Volume difference between radio and bluetooth/phone
Is there a setting I'm missing? The volume difference from when I listen to radio bluetooth/phone to when I switch to radio is drastic enough it blows the next time I start the car (defaults to radio). To be clear, I have to up the volume 2x (at least) to hear the bluetooth/phone vs the radio volume.
I'm wondering if I'm missing a setting or this is "normal"?
Normal in my experience on my 2017 TTS. It will help if you turn the volume on your phone all the way up once it's bluetooth paired to the car because you can then lower the volume in the car's stereo but it'll still be different. There is a setting in the PCM where you can tell the car to boost the BT volume as well iirc but it won't totally make up the difference. You'll find the same thing between BT and carplay if you've got that on your car.
DarienA (05-21-2023)
Thanks for the reply. Yea, I make sure the volume is fully up on the phone. I'll look for that setting you mentioned to boost the BT volume. Hopefully that can make the contrast in volume more tolerable.
This is on a 991.1S
This is on a 991.1S
