Oil Pressure Gauge vs Scope Window
Just wanted to see if anyone has seen this: Oil pressure gauge showing about ~10 psi less than the 'gauge in the scope(bar)window' readout. 2017 991.2 c2. Really new to 911 so my ignorance may show quickly. Which reading would you trust? Can they calibrated?
I had the same question with the first 911 that had digital display. The gauge is reading bars & the display is psi. Round numbers; 1 bar = 14.7 psi. They “are” calibrated! So rolling along at 30 psi, the gauge will read just above 2.
991Targa4S (05-09-2023)
I’m surprised. Using bar units on the analog oil pressure and Fahrenheit on the temps! Of course you’re right I checked by switching units under settings. I guess I just couldn’t believe engineers would mix gauges. Probably a US import change. Thanks for clearing that up
