I'm always so confused about this. I had them do the brake fluid as well, and they were adamant that the clutch is bled from a different location. I have no idea what to think at this point
I believe the clutch and brake use the same fluid reservoir.
To bleed, you'll have to bleed the brakes at each caliper.
