Traction light after changing rear tires
04-11-2023, 12:39 AM
Quote:
Originally Posted by
DC911S
The drivers door jamb will have a sticker with the pressures on it.
is that for comfort settings? ine says 36 front and 44 rear. previously it was reading 30 front and 50 rear haha
04-11-2023, 01:48 AM
moswissa
will do, I adjusted the tire pressures based on the door frame, 36psi front and 44 in the rear. Ill keep you all informed
still on the higher side. I get wheel hop and a more harsh ride with that setting.
I run 31F and 33R cold and within 5 mins of driving I’m at 33F and 35R warm. Best so far that I’ve found.
04-11-2023, 08:08 AM
moswissa
That’s full load, non-comfort. The OM and GTK App for my 991.1 GTS has three sets of pressure going from part load/comfort to full load/non-comfort.
