PPI Shows Airbag module less than DME hours
So there are around 200 fewer hours on the Airbag module than the DME hours for a 991.2 with 40k miles on it. Shop said no sign of repair/paint work done and clearly the numbers are super close, but want to get thoughts on this? 0 over-revs and no other real issues on the inspection. Would this scare you off?
The following 2 users liked this post by polobai:
joshbhatia (04-04-2023),
koala (04-05-2023)
A clean Carfax on higher end cars means nothing.. most pay out of pocket so that doesn't get reported. If there's no paintwork shown with a meter, you're usually good (can always be something behind the plastic bumpers though). Like others have said, sometimes you get funky CEL's when a car is new and parts are replaced under warranty. Airbag lights/errors on Pcars are nothing out of the ordinary. I've bought an sold literally hundreds of Pcars. If you want to post any pictures I can usually tell immediately if there is a problem. I try doing that as much as I can on here to help.
-Rick
-Rick
Appreciate it, I bought the car. Shop pulled fenders etc and said it was clean. That's why you pay for a thorough PPI! Also, looks like there was an airbag recall on 17 911s so good chance that's what happened since the miles are so close.
RP4S911 (04-06-2023)
